Three-Hinged Arches - Continuous and Point Loads
Three-Hinged Arch - Continuous Load
Bending Moment
Mm = (q L2 / 8) (4 (xm / L - (xm / L)2) - ym / yc)                               (1a)
Mm = moment at m (Nm, lbf ft)
q = continuous load (N/m, lbf/ft)
xm = x-coordinate for m (m, ft)
ym = y-coordinate for m (m, ft)
yc = y-coordinate for center hinge (m, ft)
L = horizontal distance between the supports (m, ft)
Cartesian coordinates related to a center located in the hinge of support no. 1.
Support Reactions
R1y = R2y
    = q L / 2                                (1b)
R = support force (N, lbf)
R1x = R2x
    = q L2 / (8 yc)                               (1c)
Three-Hinged Arch - Half Continuous Load
Bending Moment
Mm = (q L2 / 16) (8 (xm / L - (xm / L)2) - 2 xm / L  - ym / yc)                               (2a)
Support Reactions
R1y = 3 q L / 8                                (2b)
R2y = q L / 8                                (2c)
R1x =  R2x
     = q L2 / (16 yc)                               (2d)
Three-Hinged Arch - Horizontal Continuous Load
Bending Moment
Mm = (q L2 / 2) (xm / L - 3 xm / L + (xm / L)2)                                (3a)
Mk = (q L2 / 4) (2 (L - xk) / L - yk / yc)                                (3b)
Mk = moment at k (Nm, lbf ft)
yk = y-coordinate for k (m, ft)
xk = x-coordinate for k (m, ft)
Support Reactions
R1y = - q yc2 / (2 L)                                (3c)
R2y = q yc2 / (2 L)                                (3d)
R1x = - 3 q yc / 4                               (3e)
R2x = q yc / 4                               (3f)
Three-Hinged Arch - Eccentric Point Load
Bending Moment
Mm = (F a / 2) (2 (b / a) (xm / L) - ym / yc)                                (4a)
Mk = (F a /2) (2 (L - xk) / L - yk / yc)                                (4b)
Support Reactions
R1y = F b / L                                (4c)
R2y = F a / L                                 (4d)
R1x = R2x
      = F a / (2 yc)                               (4f)
Beams and Columns
Mechanics
Statics
Area Moment of Inertia - Typical Cross Sections I
Beams - Fixed at Both Ends - Continuous and Point Loads
Beams - Supported at Both Ends - Continuous and Point Loads
Cantilever Beams - Moments and Deflections
Continuous Beams - Moment and Reaction Support Forces
Moments and reaction support forces with distributed or point loads.
Euler's Column Formula
Calculate buckling of columns.
Mass Moment of Inertia
The Mass Moment of Inertia vs. mass of object, it's shape and relative point of rotation - the Radius of Gyration.
Stiffness
Stiffness is resistance to deflection.
Structural Lumber - Properties
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
