Stiffness
Stiffness is the resistance of an elastic body to deflection or deformation by an applied force - and can be expressed as
k = F / δ                              (1)
k = stiffness (N/m, lb/in)
F = applied force (N, lb)
δ = extension, deflection (m, in)
Mechanics
Statics
Beams - Fixed at Both Ends - Continuous and Point Loads
Beams - Supported at Both Ends - Continuous and Point Loads
Cantilever Beams - Moments and Deflections
Euler's Column Formula
Calculate buckling of columns.
Modulus of Rigidity
Shafts Torsion
The torsion of solid or hollow shafts - Polar Moment of Inertia of Area.
Three-Hinged Arches - Continuous and Point Loads
Support reactions and bending moments.
Young's Modulus, Tensile Strength and Yield Strength Values for some Materials
Young's Modulus (or Tensile Modulus alt. Modulus of Elasticity) and Ultimate Tensile Strength and Yield Strength for materials like steel, glass, wood and many more.
