Nails and Spikes - Withdrawal Force
Allowable withdrawal load or force for a common nail or spike driven into side grain perpendicular to the fibers of seasoned wood (or wet unseasoned wood) can be estimated as
F = 1380 SG5/2 D (1)
F = allowable withdrawal load or force per inch of penetration (lb/in)
SG = specific gravity of oven dry wood
D = diameter of nail or spike (inches)
Example - Nail Withdrawal Load
The specific gravity of Canadian Spruce is 0.45. The diameter of 20D nail is 0.203 inches. The allowable withdrawal force per inch of penetration can be estimated as
F = 1380 (0.45)5/2 (0.203 in)
= 38 lb/in (lb per inch penetration)
Nail Withdrawal Force Calculator
Imperial Units
Metric Units
Allowable Withdrawal Forces for some Common US Wire Nails
- for Spruce with specific gravity 0.5
Size | Length (in) | Allowable Withdrawal Force (lb) |
2d | 1 | 17.6 |
3d | 1¼ | 25.3 |
4d | 1½ | 39.9 |
5d | 1¾ | 46.5 |
6d | 2 | 58.5 |
8d | 2½ | 81.7 |
10d | 3 | 108 |
12d | 3¼ | 117 |
16d | 3½ | 141 |
20d | 4 | 198 |
30d | 4½ | 242 |
40d | 5 | 290 |
60d | 6 | 348 |
Allowable Withdrawal Forces for some Common Metric Wire Nails
Length (mm) | Diameter (mm) | Allowable Withdrawal Force (N) |
20 | 1.2 | 40.4 (4.12 kg) |
25 | 1.4 | 58.9 (6 kg) |
30 | 1.6 | 80.8 (8.23 kg) |
35 | 1.6 | 94.2 (9.61 kg) |
35 | 1.8 | 106 (10.8 kg) |
40 | 2.0 | 135 (13.7 kg) |
45 | 2.2 | 167 (17 kg) |
50 | 2.2 | 185 (18.9 kg) |
55 | 2.2 | 204 (20.8 kg) |
55 | 2.5 | 231 (23.6 kg) |
60 | 2.5 | 252 (25.7 kg) |
60 | 2.8 | 283 (28.8 kg) |
65 | 2.8 | 306 (31.2 kg) |
65 | 3.1 | 339 (34.6 kg) |
70 | 3.1 | 365 (37.2 kg) |
80 | 3.1 | 417 (42.5 kg) |
80 | 3.4 | 458 (46.7 kg) |
90 | 3.4 | 515 (52.5 kg) |
90 | 3.8 | 575 (58.7 kg) |
100 | 3.8 | 639 (65.2 kg) |
100 | 4.2 | 707 (72 kg) |
• Fasteners
Drill Bits - Conversion Chart
Convert between drill bit dimensions - gauge numbers, inches and mm.
Nails and Spikes - Metric Dimensions
Nails and spikes - commonly used metric sizes.
Nails and Spikes - US Standard Dimensions
US common wire standard nail and spikes sizes and dimensions - Imperial Units.
Structural Lumber - Properties
US Wood Screws - Nominal Sizes
Wood screws - nominal sizes vs. diameters.
US Wood Screws - Pilot Holes
Hard wood and soft wood pilot holes, shank clearance holes and countersink diameters.
Wood Beams - Strength of Material
Wood Columns - Safe Loads
Safe loads for wood columns.
Wood Hardness
Soft and hardwood - the Janka Hardness scale.
Wood Headers - Max. Supported Weight
Wood Screws - Withdrawal Force
Allowable withdrawal load force.
Wood Species - Densities
