The Prandtl Number - Pr - is a dimensionless number approximating the ratio of momentum diffusivity (kinematic viscosity) to thermal diffusivity - and is often used in heat transfer and free and forced convection calculations.
The Prandtl number can for calculations be expressed as
Pr = μ Cp / k (1)
μ = absolute or dynamic viscosity (kg/m s, lbm /(ft h))
Cp = specific heat (J/kg K, Btu/(lbm oF))
k = thermal conductivity (W/m K, Btu/(h ft2oF/ft))
Below, Prandtl numbers for methane at varying temperatures and pressures are given in figures and table .
See also other properties of Methane at varying temperature and pressure : Density and specific weight , Dynamic and kinematic viscosity , Specific heat (Heat capacity) and Thermal conductivity , and Thermophysical properties at standard conditions , as well as Prandtl number of Air , Ammonia , Carbon dioxide , Nitrogen , Propane and Water .
Methane Prandtl number at atmospheric pressure, temperature given as °C or °F:
Methane Prandtl number at varying temperatures and constant pressures, SI and Imperial units:
Methane Prandtl number at given temperatures and 1, 10 and 100 bara presure:
Temperature | Prandtl number at given pressures | ||||
[K] | [°C] | [°F] | 1 bara, 14.5 psia |
10 bara, | 100 bara, 1450 psia |
160 | -113 | -172 | 0.7721 | 0.8659 | 1.629 |
180 | -93.2 | -136 | 0.7583 | 0.8170 | 1.640 |
200 | -73.2 | -99.7 | 0.7487 | 0.7892 | 1.867 |
220 | -53.2 | -63.7 | 0.7420 | 0.7726 | 2.055 |
240 | -33.2 | -27.7 | 0.7369 | 0.7607 | 1.453 |
260 | -13.2 | 8.3 | 0.7328 | 0.7515 | 1.148 |
280 | 6.9 | 44.3 | 0.7299 | 0.7452 | 1.007 |
300 | 26.9 | 80.3 | 0.7279 | 0.7402 | 0.9304 |
320 | 46.9 | 116 | 0.7261 | 0.7370 | 0.8824 |
340 | 66.9 | 152 | 0.7243 | 0.7341 | 0.8501 |
360 | 86.9 | 188 | 0.7234 | 0.7312 | 0.8269 |
400 | 127 | 260 | 0.7216 | 0.7276 | 0.7968 |
500 | 227 | 440 | 0.7182 | 0.7233 | 0.7560 |
600 | 327 | 620 | 0.7155 | 0.7179 | 0.7385 |
700 | 427 | 800 | 0.7127 | ||
800 | 527 | 980 | 0.7099 | ||
900 | 627 | 1160 | 0.7082 | ||
1000 | 727 | 1340 | 0.7060 |
• Thermodynamics
Air - Prandtl Number
Conductive Heat Transfer
Heat, Work and Energy
Heat vs. work vs. energy.
Methane - Liquid vs. Gaseous Units
Convert between liquid and gaseous LNG and Methane units.
Online calculator, figures and table showing thermal conductivity of methane, CH4, at temperatures ranging from -160 to 725 °C (-260 to 1300 °F) at atmospheric and higher pressure - Imperial and SI Units.
Methane - Thermophysical Properties
Methane Gas - Specific Heat vs. Temperature
Specific heat of Methane Gas - CH4 - at temperatures ranging 200 - 1100 K.
Prandtl Number
A dimensionless number approximating the ratio of momentum diffusivity to thermal diffusivity.
Propane - Thermal Diffusivity vs. Temperature and Pressure
