Tabulated values of ethanol viscosity and viscosity units conversion are given below the figures.
Online Ethanol Viscosity Calculator
The calculator below can be used to calculate ethanol dynamic or kinematic viscosity at given temperatures and atmospheric pressure.
See also other properties of Ethanol at varying temperature and pressure: Density and specific weight and Specific heat (heat capacity) ,  and Thermophysical properties at standard conditions ,
as well as dynamic and kinematic viscosity of air , ammonia , benzene , butane , carbon dioxide , ethane , ethylene , methane , methanol , nitrogen , oxygen , propane and water .
Dynamic and kinematic viscosity of liquid ethanol at atmospheric pressure and varying temperature:
Dynamic and kinematic viscosity of gaseous ethanol at atmospheric pressure and varying temperature:
Dynamic viscosity of ethanol at varying temperature and 1, 10, 50 and 100 bara (14.5, 145, 725 and 1450 psia):
Kinematic viscosity of ethanol at varying temperature and 1, 10, 50 and 100 bara (14.5, 145, 725 and 1450 psia):
Dynamic viscosity of ethanol  at gas-liquid equilibrium pressure:
Kinematic viscosity of ethanol at gas-liquid equilibrium pressure:
Dynamic (absolute) and kinematic viscosity of ethanol at given temperatures and pressures, SI and Imperial units:
State Temperature Pressure Dynamic (Absolute) Viscosity Kinematic Viscosity
[K] [°C] [°F] [bara] [psia] [μPa s] [cP] [lbf s/ft2*10-6 ] [lbm /ft s*10-6 ] [lbm /ft h] [cSt],
[m2/s*10-6 ]
[ft2/s*10-6 ]
Liquid at
equilibrium
250 -23.2 -9.7 0.00270 0.0392 3141 3.141 65.60 2111 7.598 3.806 40.97
260 -13.2 8.3 0.00602 0.0874 2465 2.465 51.48 1656 5.963 3.015 32.46
265 -8.1 17.3 0.00895 0.130 2182 2.182 45.57 1466 5.278 2.685 28.90
280 6.9 44.3 0.0258 0.375 1564 1.564 32.67 1051 3.784 1.954 21.04
295 21.9 71.3 0.0661 0.959 1153 1.153 24.07 774.4 2.788 1.462 15.74
300 26.9 80 0.0877 1.27 1044 1.044 21.80 701.5 2.526 1.332 14.34
310 36.9 98 0.153 2.22 869.4 0.8694 18.16 584.2 2.103 1.121 12.07
320 46.9 116 0.252 3.66 726.6 0.7266 15.18 488.3 1.758 0.9487 10.21
340 66.9 152 0.635 9.22 524.9 0.5249 10.96 352.7 1.270 0.7019 7.555
370 96.9 206 2.02 29.3 337.0 0.3370 7.039 226.5 0.8153 0.4703 5.062
400 127 260 5.24 76.1 225.9 0.2259 4.718 151.8 0.5465 0.3319 3.573
430 157 314 11.6 169 155.4 0.1554 3.245 104.4 0.3758 0.2436 2.622
460 187 368 22.9 332 107.6 0.1076 2.248 72.32 0.2603 0.1843 1.984
490 217 422 41.0 594 72.21 0.07221 1.508 48.52 0.1747 0.1424 1.533
501.4 228 443 50.0 725 59.51 0.05951 1.243 39.99 0.1440 0.1290 1.389
Gas at equilibrium 250 -23.2 -9.7 0.00270 0.0392 7.272 0.00727 0.1519 4.886 0.01759 1214 13071
260 -13.2 8.3 0.00602 0.0874 7.586 0.00759 0.1584 5.098 0.01835 590.4 6354
265 -8.1 17.3 0.00895 0.130 7.743 0.00774 0.1617 5.203 0.01873 413.3 4448
280 6.9 44.3 0.0258 0.375 8.211 0.00821 0.1715 5.518 0.01986 160.4 1726
295 21.9 71.3 0.0661 0.959 8.676 0.00868 0.1812 5.830 0.02099 69.54 748.5
300 26.0 78.8 0.0877 1.27 8.829 0.00883 0.1844 5.933 0.02136 54.20 583.4
310 36.9 98.3 0.153 2.22 9.135 0.00914 0.1908 6.139 0.02210 33.15 356.8
320 46.9 116 0.252 3.66 9.344 0.00934 0.1952 6.279 0.02260 21.11 227.2
340 66.9 152 0.635 9.22 10.04 0.01004 0.2097 6.747 0.02429 9.485 102.1
370 96.9 206 2.02 29.3 10.93 0.01093 0.2283 7.344 0.02644 3.436 36.99
400 127 260 5.24 76.1 11.82 0.01182 0.2469 7.943 0.02859 1.476 15.89
430 157 314 11.6 169 12.77 0.01277 0.2668 8.584 0.03090 0.7168 7.715
460 187 368 22.9 332 13.96 0.01396 0.2916 9.381 0.03377 0.3806 4.096
490 217 422 41.0 594 15.98 0.01598 0.3338 10.74 0.03866 0.2149 2.313
501.4 228 443 50.0 725 17.45 0.01745 0.3645 11.73 0.04222 0.1737 1.870
Liquid 248 -25 -13 1 14.5 3260 3.260 68.09 2191 7.886 3.945 42.47
273 0 32 1 14.5 1786 1.786 37.30 1200 4.320 2.214 23.83
298 25 77.0 1 14.5 1074 1.074 22.43 721.7 2.598 1.368 14.73
323 50 122 1 14.5 694.0 0.6940 14.49 466.3 1.679 0.9092 9.787
348 75 167 1 14.5 476.0 0.4760 9.941 319.9 1.151 0.6432 6.923
351.1 77.9 172.2 1 14.5 443.1 0.4431 9.255 297.8 1.072 0.6014 6.473
Gas 351.1 77.9 172.2 1 14.5 10.37 0.01037 0.2166 6.968 0.02508 6.373 68.60
400 127 260 1 14.5 11.85 0.01185 0.2476 7.965 0.02867 8.414 90.57
500 227 440 1 14.5 14.77 0.01477 0.3084 9.924 0.03573 13.25 142.6
600 327 620 1 14.5 17.54 0.01754 0.3664 11.79 0.04244 18.96 204.1
Liquid 300 27 80 10 145 1053 1.053 22.00 707.7 2.548 1.342 14.45
323 50 122 10 145 700.0 0.7000 14.62 470.4 1.693
348 75 167 10 145 483.0 0.4830 10.09 324.6 1.168
400 127 260 10 145 227.3 0.2273 4.748 152.8 0.5499 0.3335 3.590
423.9 151 303 10 145 167.5 0.1675 3.499 112.6 0.4052 0.2588 2.786
Gas 423.9 151 303 10 145 12.57 0.01257 0.2625 8.445 0.03040 0.8243 8.873
500 227 440 10 145 14.86 0.01486 0.3103 9.985 0.03595 1.262 13.58
600 327 620 10 145 17.68 0.01768 0.3692 11.88 0.04276 1.878 20.21
Liquid 300 27 80 50 725 1080 1.080 22.55 725.5 2.612 1.370 14.74
323 50 122 50 725 726.4 0.7264 15.17 488.1 1.757
348 75 167 50 725 498.0 0.4980 10.40 334.6 1.205
400 127 260 50 725 238.8 0.2388 4.988 160.5 0.5777 0.3465 3.730
501.4 228 443 50 725 59.51 0.05951 1.243 39.99 0.1440 0.1290 1.389
Gas 501.4 228 443 50 725 17.45 0.01745 0.3645 11.73 0.04222 0.1737 1.870
600 327 620 50 725 18.97 0.01897 0.3962 12.75 0.04589 0.3621 3.898
Liquid 300 27 80 100 1450 1112 1.112 23.22 747.1 2.690 1.403 15.10
323 50 122 100 1450 758.6 0.7586 15.84 509.8 1.835
348 75 167 100 1450 520.0 0.5200 10.86 349.4 1.258
400 127 260 100 1450 252.4 0.2524 5.271 169.6 0.6106 0.3617 3.893
500 227 440 100 1450 80.68 0.08068 1.685 54.21 0.1952 0.1520 1.636
600 327 620 100 1450 23.41 0.02341 0.4889 15.73 0.05663 0.1815 1.953
Unit conversion:
Viscosity Dynamic, Absolute
  • 1 reyn = 6894.76 Pa s
Viscosity Kinematic
Fluid Mechanics
Material Properties
Thermodynamics
Viscosities
Air - Dynamic and Kinematic Viscosity
Bio Ethanol Production - Raw Materials
Raw materials used for Ethanol Bio-fuel production.
Ethane - Dynamic and Kinematic Viscosity
Online calculator, figures and tables showing dynamic and kinematic viscosity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units
Ethanol - Thermophysical properties
Chemical, physical and thermal properties of ethanol (also called alcohol or ethyl alcohol). Phase diagram included.
Ethanol Freeze Protected Water Solutions
Freezing temperature and flash points for ethanol based water solutions or brines.
Ethanol Water Mixtures - Densities vs. Temperature
Density of Ethyl Alcohol aqueous solutions.
Freeze Protection of Water based Heat Transfer Fluids
Comparing antifreezes used in water based heat transfer fluids or brines.
Liquids - Latent Heat of Evaporation
Latent heat of vaporization for fluids like alcohol, ether, nitrogen, water and more.
Naming of Organic Compounds
Nomenclature rules for different groups of organic compounds and functional groups, together with examples of use of the rules.
Nitrogen - Dynamic and Kinematic Viscosity vs. Temperature and Pressure
Online calculator, figures and tables showing dynamic and kinematic viscosity of nitrogen, N2, at varying temperature and pressure - Imperial and SI Units.
Phenols, Alcohols and Carboxylic Acids - pKa Values
For oxygen containing organic compounds this is given: pKa (the negative logarithm of the acid dissociation constant), molecular structures, molar weights, density and melting and boiling points.
Water - Dynamic (Absolute) and Kinematic Viscosity vs. Temperature and Pressure
