Ducts - Sheet Metal Gauges
Ductwork sheet metal gauges:
CommentsSheet Metal GaugeSheet Thickness
(inches)
Welded Ductwork 0 0.3120
1 0.2810
2 0.2650
3 0.2500
4 0.2340
5 0.2187
6 0.2030
7 0.1875
8 0.1720
9 0.1560
10 0.1400
11 0.1250
12 0.1090
13 0.0937
14 0.0780
15 0.0700
SMACNA1) Ductwork 16 0.0625
17 0.0560
18 0.0500
19 0.0437
20 0.0375
21 0.0343
22 0.0312
23 0.0280
24 0.0250
25 0.0218
26 0.0187
Not Suited for Ductwork 27 0.0170
28 0.0156
29 0.0140
30 0.0125
31 0.0109
32 0.0100
33 0.0093
34 0.0085
35 0.0078
36 0.0070
  •  1 inch = 25.4 mm
Recommended Gages for Circular Ducts for Heating and General Ventilation Work
Diameter
(inches)
Gauge
6 - 19 26
20 - 29 24
30 - 39 22
40 - 49 20
> 49 18
Recommended Gages for Circular Ducts for Industrial Exhaust Work
Diameter
(inches)
Gauge
< 9 24
9 - 14 22
15 - 20 20
21 - 30 18
> 30 16
Ventilation Systems
Duct Velocity
Calculate velocities in circular and rectangular ducts - imperial and SI-units - online calculator.
Ductwork - Seal Classes
Ductwork air leakage classes.
Ductwork - Supports
Recommended distance between ductwork support hangers.
Equivalent Diameter - Rectangular vs. Circular HVAC Ducts
Rectangular equivalent diameter for air flows between 100 - 50000 cfm.
