DIN - Pipe, Tube and Fittings Standards and Specifications
Industrial pipe, tube and fittings standards and specifications from the DIN - Deutsches Institut für Normung:
- DIN 76-2:1984
Thread run-outs and thread undercuts for pipe threads conforming to ISO 228 part 1 - DIN EN 259-1:2001
Wall coverings in roll form - Heavy duty wallcoverings - Part 1: Specifications; - DIN EN 259-2:2001
Wall coverings in roll form - Heavy duty wallcoverings - Part 2: Determination of impact resistance; - DIN 431:2000
Pipe nuts with thread according to DIN ISO 228-1 - DIN 906:1992
Hexagon socket pipe plugs - DIN 909:1992
Hexagon head pipe plugs - DIN 1230-P1:1992
Vitrified clay for sewerage; special fittings and adapters with flexible mechanical joint and compatible accessories; dimensions - DIN 1389:2001
WC connectors - Requirements and testing - DIN 1478:1975
Turnbuckles Made from Steel Tube or Round Steel Bar - DIN 1986-4:2003
Drainage systems on private ground - Part 4: Fields of application of sewage pipes and fittings of different materials - DIN 1988-3 Beiblatt 1:1988
Codes of practice for drinking water installations (TRWI); examples for calculation; DVGW code of practice - DIN 2406:1968
Pipelines symbols - pipe classes - DIN 2559-2:1984
Edge preparation for welding; matching of inside diameter for circumferential welds on seamless pipes - DIN 2559-3:1990
Preparation of welds; matching of inside diameters for circumferential welds on welded pipes - DIN 2559-4:1994
Preparation of welds; part 4: matching of inside diameters for circumferential welds on seamless pipes of stainless steels - DIN 2609:1991
Steel butt-welding pipe fittings; technical delivery conditions - DIN 2614:1990
Cement mortar linings for ductile iron and steel pipes and fittings; application, requirements and testing - DIN 2615-1:1992
Steel butt-welding pipes fittings; tees with reduced pressure factor - DIN 2615-2:1992
Steel butt-welding pipe fittings; tees for use at full service pressure - DIN 2616-1:1991
Steel butt-welding pipe fittings; eccentric reducers with reduced pressure factor - DIN 2616-2:1991
Steel butt-welding pipe fittings; reducers for use at full service pressure - DIN 2617:1991
Steel butt-welding pipe fittings; caps - DIN 2618:1968
Butt welding steel fittings; welding saddles, nominal pressure - DIN 2619:1968
Butt welding steel fitting; bends for welding, nominal pressure 16 - DIN 2826:1994
Hose fittings with clamp unit for steam and hot water, DN 15 up to DN 50, up to 18 bar - DIN 2848:2002
Flanged steel pipes and flanged steel or cast iron fittings with lining - PN 10, PN 25 and PN 40 - DIN 2856:1986
Capillary solder fittings; assembly dimensions and testing - DIN 2873:2002
Flanged fitting pipes and flanged steel glass lined - PN 10 and PN 25 - DIN 2874:2002
Steel flanged pipes and steel and cast iron flanged fittings lined with PTFE or PFA - Technical specifications
- DIN 2875:2002
Flanged steel pipes and flanged steel fittings with hard or soft rubber lining - Technical specifications - DIN 2876:2002
Flanged steel pipes and flanged steel fittings glass lined - Technical specifications - DIN 2950:1983
Malleable cast iron fittings - DIN 2980:1977
Screwed steel pipe fittings - DIN 2981:1982
Threaded steel pipe fitting; fittings with long screw thread - DIN 2982:1977
Screwed steel pipe fitting; parallel nipples, taper nipples - DIN 2983:1977
Screwed steel pipe fittings, bends - DIN 2986:1977
Threaded steel pipe fittings; sockets - DIN 2987-P1:1977
Threaded steel pipe fittings crosses, tees, elbows - DIN 2987-P2:1977
Threaded steel pipe fittings reducing tees and elbows - DIN 2988:1977
Reducing sockets; threaded steel pipe fittings - DIN 2990:1977
Threaded steel pipe fitting; hexagon nipple; bushings - DIN 2991:1977
Threaded steel pipe sitting; plugs, caps - DIN 2993:1977
Threaded steel pipe fittings; pipe unions - DIN 2999-2:1973
Whitworth Pipe Threads for Tubes and Fittings; Cylindrical Internal Thread and Conical External Thread, Gauging System and Use of Gauges - DIN 2999-3:1973
Whitworth Pipe Threads for Tubes and Fittings; Gauge Dimensions - DIN 2999-4:1986
Pipe threads for tubes and fittings; sizes for taper screw limit plug gauges for parallel internal thread - DIN 2999-5:1973
Whitworth Pipe Threads for Tubes and Fittings; Cylindrical Screw Limit Ring Gauges for Gauging Conical External Threads, Sizes - DIN 2999-6:1975
Whitworth Pipe Threads for Tubes and Fittings; Conical Screw Check Plugs, Sizes - DIN 3567:1963
Pipe Brackets for NW 20 to 500 - DIN 3568:1977
Clamping plates for the suspension of pipes on I and IP steel beams - DIN 3570:1968
Steel Strap for Tubes of NW 20 to 500 - DIN 3575:1962
Hanger straps with welding end for pipe hanging - DIN 3853:2001
Non-soldering and soldering compression fittings - Stud ends for use with union nut; Design sheet - DIN 3858:1988
Whitworth pipe threads for pipe couplings; parallel internal threads and taper external threads; thread dimensions - DIN 3861:2002
Non-soldering compression fittings - Compression rings - Design - DIN 3867:2003
Non-soldering compression couplings - Pressure bush for butt joints - DIN 3870:2001
Non-soldering and soldering compression fittings - Union nuts series LL - DIN 3871:1995
Non-soldering and soldering compression couplings - Socket unions - DIN 3872:2003
Non-soldering compression couplings - Union nuts for butt joints - DIN 3904:1987
Olive type compression couplings; male stud elbows - DIN 3907:1987
Olive type compression couplings; male stud tees (stud branch) - DIN 3908:1984
Solderless compression couplings with olive equal - DIN 3911:1984
Solderless compression couplings with olive elbow - DIN 3914:1987
Olive type compression couplings; male stud tees (stud run) - DIN 3942:2002
Non-soldered compression fittings - Swivel elbows with 24ü cone connectors with O-ring - Adjustable, for design and type of compression end according to DIN EN ISO 8434-1 - DIN 3943:2002
Non-soldered compression fittings - Swivel branch tees with 24ü cone connectors with O-ring - Adjustable, for design and type of compression end according to DIN EN ISO 8434-1 - DIN 3944:2002
Non-soldered compression fittings - L-adaptors with 24ü cone connectors and O-ring - Adjustable, for design and type of compression end according to DIN EN ISO 8434-1 - DIN 3945:2002
Non-soldered compression fittings - Straight stud swivel adaptor with 24ü cone connectors with O-ring - For design and type of compression end according to DIN EN ISO 8434-1 - DIN 3952:1984
Solderless compression couplings with olive male, stud elbow assemblies - DIN 3953:1984
Solderless compression couplings with olive male, stud tee ( stud branch) assemblies - DIN 3954:1984
Solderless compression couplings with olive male, stud tee (stud run) assemblies - DIN 4032:1981
Concrete pipes and fitting; dimensions, technical conditions of delivery - DIN 4060:1998
Joints of sewer and drain pipes with elastomeric seals - Requirements and testing on joints with elastomeric seals - DIN 4922-2:1981
Steel Filter Pipes for Drilled Wells with Screwed Connection DN 100 to DN 500 - DIN 4941:1965
Screw threads for drill pipes for seamless drill pipes for water and rock drillings according to the percussion drilling and core drilling method - DIN 7340:1993
Tubular rivets cut from the tube - DIN 7591:1981
Water fittings for domestic installation; Screwed unions with flat gasket for hose connection on either side, designed for nominal pressure 10 - DIN 7593:1981
Water fittings for domestic installation; Screwed unions with gasket for connection to copper tube on either side, designed for nominal pressure 10 - DIN 7632:1985
Compression couplings with spherical liner; reducers - DIN 7639:1985
Compression couplings with spherical liner; equal tees - DIN 8063-1:1986
Pipe joint assemblies and fittings for unplasticized polyvinyl chloride (U-PVC) pressure pipelines; dimensions of socket bends - DIN 8063-2:1980
Pipe Joints and Pipe Fittings for Pipes under Pressure made of Unplasticized Polyvinyl Chloride (Rigid PVC); Bends Made by Injection Moulding for Bonding; Dimensions - DIN 8063-3:2002
Pipe joints and components of unplasticized poly(vinyl chloride) (PVC U) for pipes under pressure - Part 3: Unions; Dimensions - DIN 8063-4:1983
Pipe joint assemblies and fittings for unplasticized polyvinyl chloride (PVC-U) pressure pipes; bushings, flanges, seals; dimensions - DIN 8063-5:1999
Pipe joints components of unplasticized poly(vinyl chloride) (PVC-U) for pipes under pressure - Part 5: General quality requirements, testing - DIN 8063-6:2002
Pipe joints and components of unplasticized poly(vinyl chloride) (PVC U) for pipes under pressure - Part 6: Injection-moulded elbows for solvent cementing; Dimensions - DIN 8063-7:1980
Pipe joints and their elements of unplasticized polyvinylchloride (unplasticized PVC) under pressure; tees and branches of injection moulded for cold welding, dimensions - DIN 8063-8:2002
Pipe joints and components of unplasticized poly(vinyl chloride) (PVC U) for pipes under pressure - Part 8: Injection-moulded sockets, caps and nipples for solvent cementing; Dimensions - DIN 8063-9:1980
Pipe joints and their elements for pipes of unplasticized polyvinylchloride (unplasticized PVC) under pressure; sockets reducing of injection moulded for cold welding, dimensions - DIN 8063-10:2002
Pipe joints and components of unplasticized poly(vinyl chloride) (PVC U) for pipes under pressure - Part 10: Wall bracket elbows; Dimensions - DIN 8063-11:1980
Pipe Joints and Pipe Fittings for Pipes under Pressure made of Unplasticized Polyvinyl Chloride (Rigid PVC); Sockets with Primary Element of Copper-Zinc-Alloy (Brass) for Bonding; Dimensions - DIN 8063-12:1987
Pipe joint assemblies and fittings of unplasticized polyvinyl chloride (U-PVC) pressure pipelines; dimensions of flanged and socket fittings - DIN 8975-P9:1983
Refrigeration plants; safety principles for design, equipment and installation, flexible pipe elements in the refrigerant circuit - DIN 8076-1:1984
Thermoplastics pressure pipelines; metal compression fittings for polyethylene (PE) pipes; general quality requirements; testing - DIN 8076-3:1994
Pressure pipelines made from thermoplastics materials - Part 3: Plastic joints for PE pipes; general quality requirements, testing - DIN 8906:1990
PN 40 flared flange solderless compression couplings for use in refrigerating systems - DIN 8912:1990
Coupling nuts and screwed plugs for use with PN 40 flared flange solderless compression couplings in refrigerating systems - DIN 8914:1990
90ü tapered seal rings and caps for use with PN 40 flared flange solderless compression couplings in refrigerating systems - DIN 16450:1994
Socket-fittings for pressure piping of unplasticized polyvinylchloride (PVC-U); symbols - DIN 16451-P1:1994
Ductile iron (GGG) fittings for use with unplasticized polyvinyl chloride (PVC-U) pressure pipes - technical delivery conditions - DIN 16867:1982
Glass fibre reinforced polyester resin (UP-GF) pipes, fittings and joints for use in chemical pipelines; Technical delivery conditions - DIN 16961-1:2000
Pipes and fittings of thermoplastic materials with profiled wall and smooth pipe inside - Part 1: Dimensions - DIN 16961-2:2000
Pipes and fittings of thermoplastics materials with profiled wall and smooth pipe inside - Part 2: Technical delivery specifications - DIN 16967-2:1982
Glass fibre reinforced epoxy resin (EP-GF) pipe fittings and joints; Elbows, Tees, Dimensions - DIN 16928:1979
Pipes of Thermoplastic Materials; Pipe Joints, Elements for Pipes, Laying; General Directions - DIN 16962-1:1980
Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Bends of Segmental Construction for Butt-welding, Dimensions - DIN 16962-2:1983
Pipe joint assemblies and fittings for types 1 and 2 polypropylene (PP) pressure pipes; tees and branches produced by segment inserts and necking for butt welding; dimensions - DIN 16962-3:1980
Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Bends Formed from Pipe for Butt-welding, Dimensions - DIN 16962-4:1988
Pipe joint assemblies and fittings for types 1 and 2 polypropylene (PP) pressure pipes; adaptors for fusion jointing, flanges and sealing elements; dimensions - DIN 16962-5:2000
Pipe joints and components of polypropylene (PP) for pipes under pressure, PP-H 100, PP-B 80 and PP-R 80 - Part 5: General quality requirements, testing - DIN 16962-6:1980
Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Injection Moulded Elbows for Socket-welding, Dimensions - DIN 16962-7:1980
Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Injection Moulded Tee Pieces for Socket-welding, Dimensions - DIN 16962-8:1980
Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Injection Moulded Sockets and Caps for Socket-welding, Dimensions - DIN 16962-9:1983
Pipe joint assemblies and fittings for types 1 and 2 polypropylene (PP) pressure pipes; injection moulded reducers and nipples for socket welding; dimensions - DIN 16962-10:1989
Pipe joint assemblies and fittings for types 1 to 3 polypropylene (PP) pressure pipes; injection-moulded fittings for butt welding; dimensions - DIN 16962-11:1980
Pipe Joints and Elements for Polypropylene (PP) Pressure Pipelines, Types 1 and 2; Turned and Pressed Reducing Sockets for Butt-welding, - DIN 16962-12:1999
Pipe joints and components of polypropylene (PP) for pipes under pressure, PP-H 100, PP-B 80 and PP-R 80 - Part 12: Flange adapters, flanges, sealing rings for socket welding; dimensions - DIN 16962-13:1987
Pipe joint assemblies and fittings for type 1 and type 2 polypropylene (PP) pressure pipes; pipe couplings; dimensions - DIN 16963-1:1980
Pipe Joints and Elements for High Density Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Pipe Bends of Segmental Construction for Butt-welding, Dimensions - DIN 16963-2:1983
Pipe joint assemblies and fittings for types 1 and 2 high-density polyethylene (HDPE) pressure pipes; tees and branches produced by segment inserts and necking for butt welding; dimensions - DIN 16963-3:1980
Pipe Joints and Elements for High Density Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Pipe Bends for Butt-welding, Dimensions - DIN 16963-4:1988
Pipe joint assemblies and fittings for high-density polyethylene (PE-HD) pressure pipes; adaptors for fusion jointing, flanges and sealing elements; dimensions - DIN 16963-5:1999
Pipe joints and components of polyethylene (PE) for pipes under pressure, PE 80 and PE 100 - Part 5: General quality requirements, testing - DIN 16963-6:1989
Pipe joint assemblies and fittings for high-density polyethylene (PE-HD) pressure pipes; injection-moulded fittings for butt welding; dimensions - DIN 16963-7:1989
Pipe joint assemblies and fittings for high-density polyethylene (PE-HD) pressure pipes; fittings for resistance welding; dimensions - DIN 16963-8:1980
Pipe Joints and Elements for High Density Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Injection Moulded Elbows for Socket-welding, Dimensions - DIN 16963-9:1980
Pipe Joints and Elements for High Density Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Injection Moulded Tee Pieces for Socket-welding, Dimensions - DIN 16963-10:1980
Pipe Joints and Elements for High Density Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Injection Moulded Sockets and Caps for Socket-welding, Dimensions - DIN 16963-11:1999
Pipe joints and components of polyethylene (PE) for pipes under pressure, PE 80 and PE 100 - Part 11: Flange adapters, flanges, sealing rings for socket welding; dimensions - DIN 16963-13:1980
Pipe Joints and Elements for High Pressure Polyethylene (HDPE) Pressure Pipelines, Types 1 and 2; Turned and Pressed Reducing Sockets for Butt-welding, Dimensions - DIN 16963-14:1983
Pipe joint assemblies and fittings for types 1 and 2 high-density polyethylene (HDPE) pressure pipes; injection moulded reducers and nipples for socket welding; dimensions - DIN 16963-15:1987
Pipe joint assemblies and fittings for high-density polyethylene (HDPE) pressure pipes; pipe couplings; dimensions
- DIN 16966-1:1988
Glass fibre reinforced polyester resin (UP-GF) pipe fittings and joint assemblies; fittings; general quality requirements and testing - DIN 16966-2:1982
Glass fibre reinforced polyester resin (UP-GF) pipe fittings and joints; Elbows, Dimensions - DIN 16966-4:1982
Glass fibre reinforced polyester resin (UP-GF) pipe fittings an joints; Tees, Nozzles, Dimensions - DIN 16966-5:1982
Glass fibre reinforced polyester resin (UP-GF) pipe fittings and joints; Reducers, Dimensions - DIN 16966-6:1982
Glass fibre reinforced polyester resin (UP-GF) pipe fittings and joint assemblies; collars, flanges, joint rings, dimensions - DIN 16966-7:1995
Pipe joints and their elements of glass fibre reinforced polyester resins - Part 7: Bushings, flanges, flanged and butt joints; general quality requirements and test methods - DIN 16966-8:1982
Glass fibre reinforced polyester resin (UP-GF) pipe fittings and joints; Laminated joints; Dimensions - DIN 16970:1970
Adhesives for Bonding Pipes and Pipe System Elements of Rigid PVC; General Quality Requirements and Testings - DIN 19522:2000
Cast iron drainage pipes and fittings without sockets (SML) - DIN 19530-P1:1983
Steel socket pipes and fittings for sewers; dimensions - DIN 19530-P2:1983
Steel socket pipes and fittings for sewers; technical delivery conditions - DIN 19531-10:1999
Pipes and fittings made of unplasticized polyvinyl chloride (PVC-U) socket for waste and soil discharge systems inside buildings - Part 10: Fire behaviour, quality control and installation recommendations - DIN 19532:1979
Pipelines of unplasticized plyvinyl chloride (rigid PVS, PVC-U) for drinking water supply; pipes, pipe joints, pipeline parts - DIN 19535-10:2000
High-density polyethylene (PE-HD) pipes and fittings for hot-water resistant waste and soil discharge systems (HT) inside buildings - Part 10: Fire behaviour, quality control and installation recommendations - DIN 19537-1:1983
High density polyethylene (HDPE) pipes and fittings for drains and sewers; dimensions - DIN 19537-2:1988
High-density polyethylene (HDPE) pipes and fittings for drains and sewers; technical delivery conditions - DIN 19538-10:1999
Pipes and fittings made of chlorinated polyvinyl chloride (PVC-C) for hot-water resistant waste and soil discharge systems inside buildings - Part 10: Fire behaviour, quality control and installation recommendations - DIN 19559-1:1983
Measurement of flow of waste water in open channels and gravity conduits; general information - DIN 19565-1:1989
Centrifugally cast and filled polyester resin glass fibre reinforced (UP-GF) pipes and fittings for buried drains and sewers; dimensions and technical delivery conditions - DIN 19800-P1:1973
Asbestos cement pipes and fittings for pressure pipelines; pipes, dimensions - DIN 19850-1:1996
Fibre cement pipes and fittings for sewers - Part 1: Dimensions of pipes, branches and bends - DIN 19850-2:1996
Fibre cement pipes and fittings for sewers - Part 2: Dimensions of joints - DIN 24147 P1:1998
Fittings for use in air distribution systems; overview and dimensions - DIN 28065:1993
Glass lined apparatus and pipe equipment; thermal shock resistance - DIN 28187:1991
Tubular heat exchangers; connections tube to tube sheet - DIN 28600:1983
Ductile iron pressure pipes & fittings for Gas and Water pipelines - DIN 28603:2002
Ductile iron pipes and fittings - Push-in joints - Survey, sockets and gaskets - DIN 28624:1990
Ductile iron collars for use with gas and water pipes dimensions and mass - DIN 28631:1996
Ductile iron castings for gas and water pressure pipelines; MI-fittings, socketed spigots with plane end branch; application dimensions and masses - DIN 28633:1996
Ductile iron castings for gas and water pressure pipelines; IT-fitting; all plane end tees; application, dimensions and masses - DIN 28645:1990
Ductile iron double-flanged tapers for use with gas and water pipes dimensions and mass - DIN 30670:1991
Polyethylen coatings of steel pipes and fittings - Requirements and testing - DIN 52613:1977
Thermal Insulation Testings; Determination of Thermal Conductivity by the Tube Method - DIN 53769-1:1988
Testing of glass fibre reinforced plastics pipes; determination of the longitudinal shear strength of type B pipe fittings - DIN 53769-2:1986
Testing of glass fibre reinforced plastics pipes; long-term hydrostatic pressure test - DIN 53769-3:1988
Testing of glass fibre reinforced plastics pipes; determination of initial and long-term ring stiffness - DIN 53769-6:1989
Testing of glass fibre reinforced plastics pipes; Testing of pipes and fittings under pulsating internal pressure - DIN 86041-1:1996
Welding Flanges - Part 1: Tanks and sea boxes, nominal pressure 10 and 16 - DIN 86041-2:1996
Welding flanges - Part 2: Outboard connections, nominal pressure 10, 16, 40 - DIN 86086:1996
Fittings for butt welding into copper-nickel-alloy pipelines - Technical specifications - DIN 86288:1989
Pipework on ships and marine structures; socketed steel pipes and fittings; fittings for use in shipbuilding - DIN EN 253:2003
District heating pipes - Preinsulated bonded pipe systems for directly buried hot water networks - Pipe assembly of steel service pipe, polyurethane thermal insulation and outer casing of polyethylene; - DIN EN 295-1:1999
Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 1: Requirements - DIN EN 295-2:1999
Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 2: Quality control and sampling - DIN EN 295-3:1999
Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 3: Test methods - DIN EN 295-4:1995
Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 4: Requirements for special fittings, adapters and compatible accessories - DIN EN 295-5:1999
Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 5: Requirements for perforated vitrified clay pipes and fittings - DIN EN 295-6:1995
Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 6: Requirements for vitrified clay manholes - DIN EN 295-7:1995
Vitrified clay pipes and fittings and pipe joints for drains and sewers - Part 7: Requirements for vitrified clay pipes and joints for pipe jacking - DIN EN 448:2003
District heating pipes - Preinsulated bonded pipe systems for directly buried hot water networks - Fitting assemblies of steel service pipes, polyurethane thermal insulation and outer casing of polyethylene - DIN EN 476:1997
General requirements for components used in discharge pipes, drains and sewers for gravity systems; - DIN EN 489:2003
District heating pipes - Preinsulated bonded pipe systems for directly buried hot water networks - Joint assembly for steel service pipes, polyurethane thermal insulation and outer casing of polyethylene; - DIN EN 545:2002
Ductile iron pipes, fittings, accessories and their joints for water pipelines - Requirements and test methods; - DIN EN 578:1993
Plastics piping systems; plastics pipes and fittings; determination of the opacity - DIN EN 588-1:1996
Fibre-cement pipes for sewers and drains - Part 1: Pipes, joints and fittings for gravity systems; - DIN EN 588-2:2002
Fibre cement pipes for drains and sewers - Part 2: Manholes and inspection chambers - DIN EN 598:1994
Ductile iron pipes, fittings, accessories and their joints for sewerage application - Requirements and test methods - DIN EN 607:2004
Eaves gutters and fittings made of PVC-U - Definitions, requirements and testing; - DIN EN 639:1994
Common requirements for concrete pressure pipes, including joints and fittings; - DIN EN 640:1994
Reinforced concrete pressure pipes and distributed reinforcement concrete pressure pipes (non-cylinder type), including joints and fittings - DIN EN 641:1994
Reinforced concrete pressure pipes, cylinder type, including joints and fittings - DIN EN 642:1994
Prestressed concrete pressure pipes, cylinder and non-cylinder, including joints, fittings and specific requirement for prestressing steel for pipes - DIN EN 681-1:2003
Elastomeric seals - Materials requirements for pipe joint seals used in water and drainage applications - Part 1: Vulcanized rubber; - DIN EN 705:1994
Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Methods for regression analyses and their use - DIN EN 713:1994
Plastics piping systems; mechanical joints between fittings and polyolefin pressure pipes; test method for leaktightness under internal pressure of assemblies subjected to bending - DIN EN 714:1994
Thermoplastics piping systems - Non-end-load-bearing elastomeric sealing ring type joints between pressure pipes and moulded fittings - Test method for leaktightness under internal hydrostatic pressure whithout end thrust - DIN EN 715:1994
Thermoplastics piping systems; end-load bearing joints between small diameter pressure pipes and fittings; test method for leaktightness under internal water pressure, including end thrust - DIN EN 723:1996
Copper and copper alloys - Combustion method for determination of carbon on the inner surface of copper tubes or fittings; - DIN EN 727:1995
Plastics piping and ducting systems - Thermoplastics pipes and fittings - Determination of Vicat softening temperature (VST); - DIN EN 728:1997
Plastics piping and ducting systems - Polyolefin pipes and fittings - Determination of oxidation induction time - DIN EN 754-1:1997
Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 1: Technical conditions for inspection and delivery; - DIN EN 754-2:1997
Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 2: Mechanical properties; - DIN EN 754-3:1996
Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 3: Round bars, tolerances on dimensions and form; - DIN EN 754-4:1996
Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 4: Square bars, tolerances on dimensions and form; - DIN EN 754-5:1996
Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 5: Rectangular bars, tolerances on dimensions and form; - DIN EN 754-6:1996
Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 6: Hexagonal bars; tolerances on dimensions and form; - DIN EN 754-7:1998
Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 7: Seamless tubes, tolerances on dimensions and form; - DIN EN 754-8:1998
Aluminium and aluminium alloys - Cold drawn rod/bar and tube - Part 8: Porthole tubes, tolerances on dimensions and form; - DIN EN 755-1:1997
Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 1: Technical conditions for inspection and delivery - DIN EN 755-2:1997
Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 2: Mechanical properties; - DIN EN 755-3:1995
Aluminium and aluminium alloys - Extruded rod/bar, tube and profile - Part 3: Round bars; tolerances on dimensions and form; - DIN EN 755-4:1995
Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 4: Square bars, tolerances on dimensions and form; - DIN EN 755-5:1995
Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 5: Rectangular bars, tolerances on dimensions and form; - DIN EN 755-6:1995
Aluminium and aluminium alloys - Extruded rod/bar, tube and profiles - Part 6: Hexagonal bars, tolerances on dimensions and form; - DIN EN 763:1994
Plastics piping and ducting systems - Injection-moulded thermoplastics fittings - Test method for visually assessing effects of heating; - DIN EN 802:1994
Plastics piping and ducting systems - Injection-moulded thermoplastics fittings for pressure piping systems - Test method for maximum deformation by crushing; - DIN EN 803:1994
Plastics piping systems - Injection-moulded thermoplastics fittings for elastic sealing ring type joints for pressure piping - Test method for resistance to a short-term internal pressure without end thrust
- DIN EN 804:1994
Plastics piping systems - Injection-moulded socket fittings for solvent-cemented joints for pressure piping - Test method for resistance to a short-term internal hydrostatic pressure; - DIN EN 911:1995
Plastics piping systems - Elastomeric sealing ring type joints and mechanical joints for thermoplastics pressure piping - Test method for leaktightness under external hydrostatic pressure; - DIN EN 922:1995
Plastics piping and ducting systems - Pipes and fittings of unplasticized poly(vinyl chloride) (PVC-U) - Specimen preparation for determination of the viscosity number and calculation of the K-value; - DIN EN 969:1995
Ductile iron pipes, fittings, accessories and their joints for gas pipelines - Requirements and test methods; - DIN EN 1119:1996
Plastics piping systems - Joints for glass-reinforced thermosetting plastics (GRP) pipes and fittings - Test methods for leaktightness and resistance to damage of flexible and reduced articulation joints; - DIN EN 1120:1996
Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Determination of the resistance to chemical attack from the inside of a section in a deflected condition; - DIN EN 1229:1996
Plastics piping systems - Glass-reinforced thermosetting plastics (GRP) pipes and fittings - Test methods to prove the leaktightness of the wall under short-term internal pressure; - DIN EN 1277:2004
Plastics piping systems - Thermoplastics piping systems for buried non-pressure applications - Test methods for leaktightness of elastomeric sealing ring type joints; - DIN EN 1716:1997
Plastics piping systems - Polyethylene (PE) tapping tees - Test method for impact resistance of an asssembled tapping tee; - DIN EN 10233:1994
Metallic materials; tube; flattening test - DIN EN 10234:1994
Metallic materials; tube; drift expanding test - DIN EN 10242:1995
Threaded pipe fittings in malleable cast iron;
• Piping Codes and Standards
American vs. British Piping Standards
US American (ASTM) vs. British (BSi) piping standards - specifications, grades and material descriptions.
Carbon and Stainless Steel Welding Neck Flange Bores
Flange bores of welding neck flanges according ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings.
DIN - the German Institute for Standardization.
Deutsches Institut für Normung - DIN - pipe, tube and fittings standards and specifications.
DIN - Valve Standards
An overview of DIN - Deutsches Institut für Normung - valve standards.
Malleable Iron Threaded Fittings - Pressure vs. Temperature Rating
ASME/ANSI B16.3 Malleable Iron Threaded Fittings - Pressure and Temperature Ratings.
Polyester - Chemical Resistance
Chemical resistance of Polyester to products like Acetic acid, Diesel oil and others.
PP - PolyPropylene Pipes - Support Spacing
Maximum distance between PolyPropylene pipes supports.
