Dowtherm A
Physical properties of Dowtherm A.
DOWTHERM™ A from The Dow Chemical Company is a heat transfer fluid suitable for non-pressurized liquid phase systems with a maximum temperature of 550°F (288°C).
DOWTHERM™ A is a eutectic mixture of two very stable compounds
  • biphenyl - C12H10
  • diphenyl oxide - C12H10O
with practically the same vapor pressures - suitable as a indirect heat transfer fluid for
  • liquid phase systems - 15oC to 400oC (60oF to 750oF)
  • vapor phase systems - 257oC to 400oC (495oF to 750oF)
Physical properties
  • freeze point - 12oC (56.6oF)
  • boiling point (atmospheric) - 257oC (494.8oF)
  • flash point (SETA) - 113oC (236oF)
  • Fire point (C.O.C) - 118oC (245oF)
  • autoignition temperature - 599oC (1110oF)
  • density (25oC, 75oF) - 1056 kg/m3 (66 lb/ft3)
Dowtherm A - Saturated Liquid Properties Chart
Vapor Pressure, Viscosity, Specific Heat, Thermal Conductivity and Density are indicated in the chart below:
Dowtherm A Saturated Liquid Properties Chart
  • Heating Systems
  • Thermodynamics
  • The Engineering ToolBox (2010). Dowtherm A . [online] Available at: https://www.engineeringtoolbox.com/dowtherm-a-pysical-properties-d_1591.html [Accessed Day Month Year].
