Air - SCFM versus ACFM and ICFM
SCFM - Standard Cubic Feet per Minute
It is common to rate compressed air consumption in Standard Cubic Feet per Minute - SCFM.
The SCFM - Standard Cubic Feet per Minute - determines the weight of air to fixed or "Standard" conditions. There are several definitions of SCFM. The most common used in the United States is with the "sea-level" properties:
- 14.696 Pounds per Square Inch (psia)
- 60 Degrees Fahrenheit ( oF) (520 o R)
- 0% Relative Humidity (RH)
Europeans normally use one ata and 0 oC as SCFM.
Note that the The Compressed Air & Gas Institute and PNEUROP have adopted the definition used in ISO standards with dry (0% relative humidity) air at 14.5 psia (1 bar) and 68 oF (20 oC).
ACFM - Actual Cubic Feet per Minute
Real life "actual conditions" are seldom "standard conditions". When
- pressure is applied a volume of air - it gets smaller
- vacuum is applied to a volume of air - it expands
The actual air volume flow is often termed ACFM - Actual Cubic Feet per Minute .
The Actual Cubic Feet per Minute - ACFM - depends on the
- pressure
- temperature
- humidity
of the actual air.
The conversion from SCFM to ACFM can be expressed
ACFM = SCFM [P std / (P act - P sat Φ)](T act / T std ) (1)
ACFM = Actual Cubic Feet per Minute
SCFM = Standard Cubic Feet per Minute
P std = standard absolute air pressure (psia)
P act = absolute pressure at the actual level (psia)
P sat = saturation pressure at the actual temperature (psi)
Φ = Actual relative humidity
T act = Actual ambient air temperature ( o R)
T std = Standard temperature ( o R)
Note!
P sat Φ ƒ < P act
Online SCFM - ACFM Calculator
The calculator below can used to calculate ACFM:
Example - SCFM to ACFM
The actual CFM of a compressor operating at "non-standard" conditions like
- elevation 5000 feet (1500 m) - atmospheric pressure P act = 12.23 psia
- temperature 80 oF - absolute temperature T act = 540 o R
- saturation pressure P sat = 0.5069 psia
- relative humidity Φ = 80%
- demand: 100 SCFM
can be calculated as
ACFM = (100 SCFM) [(14.7 psia) / ((12.23 psia) - (0.5069 psia) (80 / 100))]((540 o R ) / (520 o R))
= 129.1
ICFM - Inlet Cubic Feet per Minute
Inlet Cubic Feet per Minute - ICFM - is used by compressor vendors to establish conditions in front of additional equipment like inlet filter, blower or booster.
When air passes through the filter there will be a pressure drop. The conversion from ACFM to ICFM can be expressed as
ICFM = ACFM (P act / Pf ) (Tf / T act ) (2)
ICFM = Inlet Cubic Feet per Minute
Pf = Pressure after filter or inlet equipment (psia)
Tf = Temperature after filter or inlet equipment ( o R)
Note!
The Ideal Gas Law is accurate only at relatively low pressures and high temperatures. To account for the deviation from the ideal situation, another factor is included. It is called the Gas Compressibility Factor, or Z-factor . This correction factor depends on the pressure and temperature for each gas considered.
The True Gas Law, or the Non-Ideal Gas Law, becomes:
P V = Z n R T (3)
Z = Gas Compressibility Factor
n = number of moles of gas present
Air Volume Conversion Factors
Air volume conversion factors related to air with temperature 70°F (21.1°C) :
Air Temperature | Factor | |
°F | °C | |
0 | -17.2 | 1.152 |
10 | -12.2 | 1.128 |
20 | -6.7 | 1.104 |
30 | -1.1 | 1.082 |
40 | 4.4 | 1.060 |
50 | 10.0 | 1.039 |
60 | 15.6 | 1.019 |
70 | 21.1 | 1.000 |
80 | 26.7 | 0.981 |
90 | 32.2 | 0.964 |
100 | 37.8 | 0.946 |
110 | 43.3 | 0.930 |
120 | 48.9 | 0.914 |
130 | 54.4 | 0.898 |
140 | 60.0 | 0.883 |
150 | 65.6 | 0.869 |
160 | 71.1 | 0.855 |
170 | 76.7 | 0.841 |
• Gases and Compressed Air
Air Compressor - Power Cost per Year
Yearly power cost for operating an air compressor.
Air Compressors - Maximum Air Flow vs. Inlet Pipe Size
Inlet pipe size and maximum air flow.
Air Tools - Air Consumption
Air consumption of air tools.
Atmospheric Pressure vs. Elevation above Sea Level
Elevation above sea level - in feet and meter - with barometric and atmospheric pressure - inches mercury, psia, kg/cm2 and kPa.
Moist Air - Relative Humidity
Relative humidity in moist air is the ratio of partial vapor pressure to air pressure.
Rating of Air Compressors and Air Equipment
Common rating terms for air flow capacity are ICFM, FAD, ANR, SCFM or nl/min.
The Ideal Gas Law
Calculate specific work done by pumps, fans, compressors or turbines.
Types of Air Compressors
Reciprocating, rotary screw and rotary centrifugal air compressors.
Vacuum Pipes - Pressure Loss vs. Air Flow
Calculate pressure drops in vacuum pipe lines.
Water - Saturation Pressure vs. Temperature
