The Engineering ToolBox Web Google
Pumps - Specific Suction Speed
Specific Suction Speed may be used to determine what general pump design to use for maximum efficiency
Suction Specific Speed may be used to determine what pump geometry - radial, mixed flow or axial - to use for maximum efficiency and prevent cavitation. Suction Specific Speed is commonly used as a basis for estimating the safe operating range of a pump.
Suction Specific Speed is dimensionless and are expressed as
Nss = ω q1/2 / NPSHa3/4         (1)
Nss = Suction Specific Speed
ω = pump shaft rotational speed (rpm)
q = flow rate capacity (m3/h, l/s, m3/min, US gpm, British gpm) at Best Efficiency Point BEP
NPSHa = available Net Positive Suction Head (m, ft)
Specific Suction Speed can be compared with Specific Speed but instead of using the total head of the pump, the available Net Positive Suction Head N.P.S.H.a is used.
As a rule of thumb the Specific Suction Speed should be below 8500 (calculated with US gpm) to avoid cavitation.
Online Specific Suction Speed Pump Calculator
The calculator below can used to calculate pump specific speed:
ω - pump shaft rotational speed (rpm)
q -  flow rate (m3/h, l/s, m3/min, US gpm, British gpm)
NPSHr - required Net Positive Suction Head (m, ft)
Note! When comparing pumps and their documentation be aware of the units used.
Suction Specific Speed - Ss - is useful in determining the required operating conditions on the suction side of the pump. For geometrically similar pumps the Ss have the same value.
Empirical studies indicates that higher Suction Specific Speed is, the narrower is the safe operating range from its Best Efficiency Point (BEP). Pump models with Ssd (US units) less than 11000 have more stable operation and are more reliable.
Convert between Imperial units (gpm) and Metric units (m3/h, l/s)
Example - Specific Suction Speed
The available Net Suction Head - NPSHa - of a pump is determined to be 20 ft. With a rotational speed of 1750 rpm and a flow rate of 500 US gpm the Specific Suction Speed can be calculated as
Nss = (1750 rpm) (500 gpm)1/2 / (20 ft)3/4
    = 4138
Well below the limit 8500 to avoid cavitation.
  • Pumps Piping systems and pumps - centrifugal pumps, displacement pumps - cavitation, viscosity, head and pressure, power consumption and more
Search the ToolBox
9 11 11
handheld Engineering ToolBox - optimized for mobile devices! 3D Engineering ToolBox - draw and model technical applications!
Resources, Tools and Basic Information  for Engineering and Design of Technical Applications!
