Typical weight and dimensions of PVC and CPVC pipes according ASTM D1785 "Standard Specification for Poly(Vinyl Chloride) (PVC) Plastic Pipe, Schedules 40, 80, and 120" can be found in the table below:
| PVC and CPVC Pipes - Schedule 40 | |||||
| Nominal Pipe Size (inches) |
Outside Diameter (inches) |
Minimum Wall Thickness (inches) |
Nominal Inside Diameter (inches) |
Weight (lb/ft) |
| PVC | CPVC | ||||
| 1/2 | 0.840 | 0.109 | 0.622 | 0.16 | 0.17 |
| 3/4 | 1.050 | 0.113 | 0.824 | 0.21 | 0.23 |
| 1 | 1.315 | 0.133 | 1.049 | 0.32 | 0.34 |
| 1 1/4 | 1.660 | 0.140 | 1.380 | 0.43 | 0.46 |
| 1 1/2 | 1.900 | 0.145 | 1.610 | 0.51 | 0.55 |
| 2 | 2.375 | 0.154 | 2.067 | 0.68 | 0.74 |
| 2 1/2 | 2.875 | 0.203 | 2.469 | 1.07 | 1.18 |
| 3 | 3.500 | 0.216 | 3.068 | 1.41 | 1.54 |
| 4 | 4.500 | 0.237 | 4.026 | 2.01 | 2.20 |
| 5 | 5.563 | 0.258 | 5.047 | 2.73 | |
| 6 | 6.625 | 0.280 | 6.065 | 3.53 | 3.86 |
| 8 | 8.625 | 0.322 | 7.981 | 5.39 | 5.81 |
| 10 | 10.750 | 0.365 | 10.020 | 7.55 | 8.24 |
| 12 | 12.750 | 0.406 | 11.938 | 10.01 | 10.89 |
| 14 | 14.000 | 0.438 | 13.124 | 11.80 | |
| 16 | 16.000 | 0.500 | 15.000 | 15.43 | |
| PVC and CPVC Pipes - Schedule 80 | |||||
Weight (lb/ft) |
| PVC | CPVC | ||||
| 1/2 | 0.840 | 0.147 | 0.546 | 0.20 | 0.22 |
| 3/4 | 1.050 | 0.154 | 0.742 | 0.27 | 0.30 |
| 1 | 1.315 | 0.179 | 0.957 | 0.41 | 0.44 |
| 1 1/4 | 1.660 | 0.191 | 1.278 | 0.52 | 0.61 |
| 1 1/2 | 1.900 | 0.200 | 1.500 | 0.67 | 0.74 |
| 2 | 2.375 | 0.218 | 1.939 | 0.95 | 1.02 |
| 2 1/2 | 2.875 | 0.276 | 2.323 | 1.45 | 1.56 |
| 3 | 3.500 | 0.300 | 2.900 | 1.94 | 2.09 |
| 4 | 4.500 | 0.337 | 3.826 | 2.75 | 3.05 |
| 5 | 5.563 | 0.375 | 4.813 | 3.87 | |
| 6 | 6.625 | 0.432 | 5.761 | 5.42 | 5.82 |
| 8 | 8.625 | 0.500 | 7.625 | 8.05 | 8.83 |
| 10 | 10.750 | 0.593 | 9.564 | 12.00 | 13.09 |
| 12 | 12.750 | 0.687 | 11376 | 16.50 | 18.0 |
| 14 | 14.000 | 0.750 | 12.500 | 19.30 | |
| 16 | 16.000 | 0.843 | 14.314 | 25.44 | |
9 12 8
