The Engineering ToolBox Web Google
Calcium Silicate Insulation
Thermal conductivity - temperature and k-values
Non-asbestos Calcium Silicate insulation board and pipe insulation feature with light weight, low thermal conductivity, high temperature and chemical resistance.
Calcium Silicate is rigid, high density material used for high temperature applications ranging 250 oF (121 oC) - 1000 oF (540 oC).
The relation between temperature and thermal conductivity is indicated in the diagram below:
Calcium Silicate Insulation k values diagram
  • Insulation Heat transfer and heat loss from buildings and technical applications - insulation methods and coefficients to reduce energy consumption
Search the ToolBox
9 11 11
handheld Engineering ToolBox - optimized for mobile devices! 3D Engineering ToolBox - draw and model technical applications!
Resources, Tools and Basic Information  for Engineering and Design of Technical Applications!
